drafferty
Jul 27, 2025Aspirant
AC3000 RBR50 compatible with CAT6 cable
I understand this is older MESH system. This router has most recent firmware 2.7.5.6 For one will this network support 1GB? Current ISP and plan is 500mbps. All works as planned. What speeds shoul...
CrimpOn
Jul 27, 2025Guru - Experienced User
That sounds like an issue to take up with the ISP. Maybe they did no provision the modem correctly?
What people often do when troubleshooting this sort of issue is connect a computer directly to the ISP device and attempt to reproduce the problem. Not exactly easy to do in your situation.
