drafferty
Jul 27, 2025Aspirant
AC3000 RBR50 compatible with CAT6 cable
I understand this is older MESH system. This router has most recent firmware 2.7.5.6 For one will this network support 1GB? Current ISP and plan is 500mbps. All works as planned. What speeds shoul...
drafferty
Jul 30, 2025Aspirant
Hopefully getting new isp modem that will support 1GB speed. Would you recommend any of the newer mesh systems if I were to upgrade from the rbr50 ac3000? If I look at devices , 130 devices but what see 40 that are online. laptops, tvs, cameras, ps5 nothing crazy. house is single floor, sq2500. any recommendations is appreciated.
- FURRYe38Jul 30, 2025Guru - Experienced User
For that size of home, a router unit and just one RBS would be needed. Give the RBKE962 a review.
