RickPC's avatar
RickPC
AC3000 vs. AC2200: Maximum Distance Between Satellites in Daisy Chain Configuration
I am trying to determine whether there is any a material difference between the AC3000 and AC2200 mesh network, if I need to maximize distance between two satellites in a daisy chain configuration.
    • RickPC's avatar
      RickPC
      I can set the first satellite wtihn 30 ft of router.  Howevere, I want to run about 60 feet or a bit more rom that satellite to the next.  it would be across an open space through two windows..home to garage office.
      • FURRYe38's avatar
        RBS should not be closer than 30 feet. Any closer and the wifi over lap between the RBR and RBS becomes bad. Causes problems.
