aeiou_y's avatar
aeiou_y
Follower
Jan 21, 2019
Access Control and Whitelist / Block New Connections Primary Network - Allow new devices on Guest
So, after spending sometime researching this, I'm pretty shocked that this setup is not possible.
Objectives:
1) Primary network with access control turned on that blocks new devices by default and only allows devices with white-listed MAC addresses to connect
2) Guest network that allows new devices to connect
This is an extremeley common used case, but I think may be one the Orbi does NOT support.
When you go to the UI...Advanced>Security>Access control, it seems the access controls apply to both the Primary and Guest network, which effectively makes them pointless.
Am I missing something? Will be returning this product if use case above is not supported.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi aeiou_y
    Welcome to NETGEAR Community!
    Guest network cannot be excluded from the Access Control list.
    You can also monitor list of connected devices via the Orbi app and web UI to allow and to block devices.
    Blanca
    Community Team
    • farmboy3000's avatar
      farmboy3000
      Star
      I'm looking for the same funtionality as the OP.  My teenage son is pretty smart and figured out how to change his MAC address anytime his time limit is exceeded.  He's blocked for maybe 3 minutes and then he's back on again.  The ability to have a whitelist and block all "new" devices would solve this issue.
