aeiou_y
Jan 21, 2019Follower
Access Control and Whitelist / Block New Connections Primary Network - Allow new devices on Guest
So, after spending sometime researching this, I'm pretty shocked that this setup is not possible.
Objectives:
1) Primary network with access control turned on that blocks new devices by defa...
Jun 01, 2019Guru - Experienced User
You might give Armor or Circle a try and see if any of these helps.
Forums are located here:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Check for default parental controls currently offered in the UI, check out the user manual for this.
Maybe remove the device from time to time as punishment for changing the MAC address. :smileywink:
farmboy3000 wrote:I'm looking for the same funtionality as the OP. My teenage son is pretty smart and figured out how to change his MAC address anytime his time limit is exceeded. He's blocked for maybe 3 minutes and then he's back on again. The ability to have a whitelist and block all "new" devices would solve this issue.
farmboy3000
Jun 01, 2019Star
Thanks...I'm already using Circle. Yes, I can remove the new device when it appears but that would also mean that I would need to be constantly watching the network for new devices. Also, I go to bed before my son does, so I need the bedtime limits to work without me having to stay up all night checking for new devices.
- FURRYe38Jun 01, 2019Guru - Experienced User
Might contact NG support to see if Armour or any other Circle or Access or parental controls settings would help look for new devices and block them. Does access controls offer blocking of new devices?
I would make contact with NG support to see what configurations, if any can help with this.
Remove the device when you go to bed and return in the morning. :smileyfrustrated:
So does this not work for you in Access Controls?
farmboy3000 wrote:Thanks...I'm already using Circle. Yes, I can remove the new device when it appears but that would also mean that I would need to be constantly watching the network for new devices. Also, I go to bed before my son does, so I need the bedtime limits to work without me having to stay up all night checking for new devices.
