aeiou_y
Jan 22, 2019Follower
Access Control and Whitelist / Block New Connections Primary Network - Allow new devices on Guest
So, after spending sometime researching this, I'm pretty shocked that this setup is not possible.
Objectives:
1) Primary network with access control turned on that blocks new devices by defa...
farmboy3000
Jun 01, 2019Star
Thanks...I'm already using Circle. Yes, I can remove the new device when it appears but that would also mean that I would need to be constantly watching the network for new devices. Also, I go to bed before my son does, so I need the bedtime limits to work without me having to stay up all night checking for new devices.
Jun 01, 2019Guru - Experienced User
Might contact NG support to see if Armour or any other Circle or Access or parental controls settings would help look for new devices and block them. Does access controls offer blocking of new devices?
I would make contact with NG support to see what configurations, if any can help with this.
Remove the device when you go to bed and return in the morning. :smileyfrustrated:
