aeiou_y
Jan 21, 2019Follower
Access Control and Whitelist / Block New Connections Primary Network - Allow new devices on Guest
So, after spending sometime researching this, I'm pretty shocked that this setup is not possible.
Objectives:
1) Primary network with access control turned on that blocks new devices by defa...
farmboy3000
Jun 01, 2019Star
Thanks...Apparently I didn't see the checkbox to block new devices in Access Control. This should work. Thanks!
Jun 01, 2019Guru - Experienced User
Let us know how it works out for you.
farmboy3000 wrote:Thanks...Apparently I didn't see the checkbox to block new devices in Access Control. This should work. Thanks!
