mc64
Oct 22, 2018Tutor
Access Control Bug in Orbi V2.2.1.210
Until the last firmware upgrade, access control worked fine. I had "prevent new devices from connecting" enabled as well. When I recently installed a new device and went to allow it to connect as I'v...
Oct 22, 2018Guru - Experienced User
Have you tried a full factory reset on the Orbi router and setup from scatch or manually installed the router FW and reset and setup from scratch to see if the problem in the control still appears? May need to try this and see.
