jbrown316
Nov 04, 2020Apprentice
Access control issue/bug with Orbi 2.7.1.60
Since I upgraded to the latest firmware, the Access Control feature in Advanced...Security in the UI doesn't work properly. When I turn access to certain devices off, it is also turning off access t...
Jan 18, 2021Guru - Experienced User
Are you setting IP address reservations for the devices in the access control list before enabling it?
Contact NG support about this to let them know. NG doesn't hang out in the forums to check for problems.
jbrown316
Jan 18, 2021Apprentice
No, not reserving IPs. Thanks for the help.
- FURRYe38Jan 18, 2021Guru - Experienced User
You might try reserving IP addresses for devices that you will be controlling. Disable Access control, reboot, then setup IP address reservations for your devices, save and apply. After the reboot, setup Access Control
- jbrown316Feb 01, 2021Apprentice
I did try reserving IPs as you suggested, but that didn't seem to fully resolve the issue. It may not be quite as frequent as before (and that could just be coincidence), but I will still lose my Internet connection on other devices when I turn on/off devices that I set up static IPs for. It seems to happen whether I use the UI Access Control page or the app's Manage Devices page. It is quite frustrating.
- FURRYe38Feb 01, 2021Guru - Experienced User
You might send a forum moderator a message and let then know what your seeing in recent versions of FW.
Also you might downgrade to v16:
