qtschlepper
Oct 15, 2018Star
Access Control randomly blocking approved devices on V2.2.1.210
RBR50
After upgrading to the V2.2.1.210 router firmware, i'm finding that devices that have approved MacID addresses and have been previosly on the network for months are suddenly being blocked in...
Oct 22, 2018Guru - Experienced User
mc64 wrote:
I'm having the same problems. I've had to turn off access control, which is VERY annoying.
qtschlepper
Oct 22, 2018Star
FURRYe38 wrote:
I got a working solution from the Netgear team.
it's a bit complex but as of now the problem went away. You need to do a manual install of the firmware (download from the site) upload it manually to each of the Orbi units on your network, an then do a factory reset. Before you start, save the configuration file and then load it after the reset. That seems to do it. I'm guessing they are working on a fix for the automatic firmware update, but I was Patient Zero, and this fix worked.
- mc64Oct 23, 2018Tutor
"Manually install firmware and perform factory reset?" That's not really a working solution. I've *been* a network engineer and that's a lame response for terrible QA.
- qtschlepperOct 23, 2018Star
FURRYe38 wrote:
It's meant as a work around solution for now until NG gets the bug fixed.
As much as I agree with you, this may in fact be the first time in history this actually worked. As of today the problem still hasn't reappeard. But i'm checking twice a day, as i'm skeptical as well.
- FURRYe38Oct 23, 2018Guru - Experienced User
Keep us posted. If NG knows about it, hopefully it should appear in next FW update.
That's not a reasonable workaround IMO. I've worked for software product companies, IMO, QA/relase process needs serious improvement. The bug fix should be a priority and I don't see any indication that it is. As a 22-year veteran in this industry, I'm appalled.
Well untill next FW update, users can use the work around. not the first bug nor probably the last.
Good Luck.
Or users can go elsewhere, i.e. another vendor. It's probably what I'll do.
Good Luck then. Enjoy. :smileywink:
- FURRYe38Jan 15, 2019Guru - Experienced User
Was wondering how yours is working for you?
