thethirdnut
May 22, 2020Guide
Access Control still doesn't work?
Running an RBR50 with 1 x RBS50 backhauled over ethernet. Both running V2.5.1.8.
Is there still a known issue, no real fix for Access Control randomly moving devices to BLOCKED status even when intervening and manually setting back to ALLOW?
Workaround I have in place is having Allow all new devices to connect checked which is obviously not ideal if people go thru all the trouble of adding MACs for approved devices, etc.
Thanks in advance.
I would make contact with NG support and notify them of this issue your still seeing.
thethirdnut wrote:Is there still a known issue, no real fix for Access Control randomly moving devices to BLOCKED status even when intervening and manually setting back to ALLOW?
Do you use the Orbi web interface or the Orbi "app"?
Primarily the web interface. Occasionally check the app for status, etc but do must of the configuration through web page.
RE: Factory Reset - is it expected to do so everytime the firmware updates on these units?
