Dogzelda
Jan 24, 2019Follower
access router configuration
I am running my Orbi system behind an ATT Uverse router. I have it setup in AP mode with the wifi on the router turned off. Everything works great. I need to access the router to configure port forwa...
ekhalil
Jan 24, 2019Master
Orbi should not have any effect on the IP addressing as this is all managed by the ATT Uverse router. you should still be able to reach the router on 192.168.1.254 if you did not change the IP address range in the router.
