lethcoeb
Jun 09, 2018Follower
Accessing Netgear C7100V in bridge mode behind Orbi
I have an Orbi RBR50 as the router in a system with the Netgear C7100V set in bridge mode.
Of course, during setup I was able to access the C7100V via 192.168.0.1.
Now with the Orbi in place, I c...
st_shaw
Jun 10, 2018Master
This usually works with modems in bridge mode. I have this setup now with a DSL modem. I'm not sure about this modem, but I expect this will work:
1. Take a laptop or desktop computer with a wired Ethernet port and manually set the IP address for the wired connecton to 192.168.0.2. Turn off any WiFi on the computer.
2. Wire the computer to one of the unused LAN ports on the modem.
3. Connect to the modem GUI at 192.168.0.1 as before.
Note that you cannot normally access the modem from computers on the LAN side of Orbi (or any other router you might use.)
