Bigblueearth
Jul 17, 2019Aspirant
Accessing remotely RBK 50
I have two Orbi networks but only see one when I try to connect remotely
Remote Access using the Orbi "app" or using the web interface?
- BigblueearthAspirantThe app
I don't know if this is getting through, keep getting message that failed to post, correct highlighted errors. I do not see any highlighted errors
- BigblueearthAspirantIt is out of state so I can't check.
It is served by Comporium in Cedar Mountain NC
You'll need to find out as if the modem has a built in router in front of the Orbi router. If it doesn, this can impede remote access with the Orbi.
Sorry for delay but I am not at location.
There is just a modem in front of it.
Thanks
Henry
This modem a modem only or does it have a built in router with the modem?
