RalphRino
Dec 27, 2018Tutor
Adding 2.4 ghz devices to Orbi
I have the Orbi RBR20 which is not listed in the model drop down. I also have an Android phone runing Oreo. I have bought two wi-fi plugs to connect to Alexa and a La Crosse weather station that us...
RalphRino
Dec 27, 2018Tutor
I tried powering down the 5g to 25%. It didn't work. A 0% option is needed.
Dec 27, 2018Guru - Experienced User
How far was the device from the router when you turned it down? Did you turn OFF the satellites as well while you did this?
When you do this, turn OFF all satellites leaving just the router. Then go out as far as possible with the device from the router and see if it will connect to the 2.4Ghz long enough to do the setup...
