RalphRino
Dec 27, 2018Tutor
Adding 2.4 ghz devices to Orbi
I have the Orbi RBR20 which is not listed in the model drop down. I also have an Android phone runing Oreo. I have bought two wi-fi plugs to connect to Alexa and a La Crosse weather station that us...
RalphRino
Dec 27, 2018Tutor
I tried powering down the 5g to 25%. It didn't work. A 0% option is needed.
ekhalil
Dec 27, 2018Master
Please use the following suggestion from another user:
If this does not help I can lead you through how to reduce the power of the 5GHz band to around 0.
- CrimpOnDec 27, 2018Guru - Experienced User
Could you please identify the brand/model of WiFi plug you want to install? There are numerous Community members who have experience with specific brands who might be able to help. I, for example, was able to install TP-Link "Mini Smart Plug" with no problems, even though my phone was connected to the Orbi at 5G. I did not have to change the SSID, turn off 5G, or turn down the power of 5G.
What are you trying to connect?
