RalphRino
Dec 27, 2018Tutor
Adding 2.4 ghz devices to Orbi
I have the Orbi RBR20 which is not listed in the model drop down. I also have an Android phone runing Oreo. I have bought two wi-fi plugs to connect to Alexa and a La Crosse weather station that us...
RalphRino
Dec 28, 2018Tutor
I know some people cannot help but patronize on these sites. I am not a neophite with hardware/software setup. I have tried to connect two brands of plug, one was TP Link and a La Crosse weather station. The device instructions for all three devices basically say down load our app and follow the isntructions. They have not required Bluetooth conection. They reach a point where you select a network and input the password. This step is supposed to give the device the network name and password. It times out over and over and over.
There are posts on the community which agree that if your phone is not connected at 2.4 ghz you cannot complete this step. The only way I have been able to connect my devices is to turn off the Orbi and turn on an old router where the 2.4 and 5 ghz are seperate networks. I connect my phone to 2.4 and the devices have configured on the first try. This - and the device information through the Orbi attached devices screen accessed via the dashboard on the router which shows my phone connected at 5 ghz - is why I am making the conclusion that I am making.
More power to those have been able to connect using their phones connected at 5 ghz. Were you using a Galaxy S9 running Oreo? You say the Orbi handled the bridge between the two. My experience says it doesn't. Netgear needs to provide a simple way to accomplish this. Until they do, I will keep my old router to connect new devices.
CrimpOn
Dec 28, 2018Guru - Experienced User
Can you please specify the models of smart plugs and La Crosse weather station which you were connectingt?
The comment about bluetooth was generic, not specific to your situation. One of the smart plugs apps addressed by a community post specifically mentions that the default (for that plug) is to use bluetooth and if the user does not want to use bluetooth, they were to hold the button down longer until the blue light flashed slower. So, there are a lot of factors in play, and every situation seems to be different.
Is it the case that now that your devices are connected, you can control them with their respective smartphone apps when your phone is connected to 5G?
