Pranit6
Nov 17, 2018Aspirant
Adding a first orbi satellite
Hi guys. I plan to add a first satellite and wanted to know if instead of just buying a satellite off Amazon as a single unit, could I get another dual pack (router +satellite) and just add the sate...
- Nov 17, 2018Yes, you can add the Satellite in the pack as a Satellite in your system.
You just need to sync the new Satellite with your existing Router by following the procedure of adding a new Satellite.
ekhalil
Nov 17, 2018Master
- Pranit6Nov 20, 2018Aspirant
You just need to sync the new Satellite with your existing Router by following the procedure of adding a new Satellite.thankyou so much!!!
https://inro.in/watch-movies-online/ inro.in/cyberghost/ inro.in/expressvpn/
