Pranit6's avatar
Pranit6
Adding a first orbi satellite
Hi guys. I plan to add a first satellite and wanted to know if instead of just buying a satellite off Amazon as a single unit, could I get another dual pack (router +satellite) and just add the sate...
  • ekhalil's avatar
    Nov 17, 2018
    Yes, you can add the Satellite in the pack as a Satellite in your system.
    You just need to sync the new Satellite with your existing Router by following the procedure of adding a new Satellite.
