rugby49
Dec 12, 2016Aspirant
Adding a Satellite (One main and two Satellites)
Okay still having problems with PS4 and XBox One S dropping connections. Just noticed on Amazon that additional satellites available through one vendor to purchase but it is $260.00. Anyone try one...
DarrenM
Dec 16, 2016Sr. NETGEAR Moderator
Hello rugby49
Have you updated the firmware on Orbi we have done some updates to help stability also have you tried to change wireless channels on the router or maybe try to position the satellite in a different location.
DarrenM
rugby49
Dec 17, 2016Aspirant
Just updated the firmware to 1.4.0.16. No have not changed the channel. Still have it set to Auto. Unfortunately due to the time of year and two birthdays before Christmas, I just do not have the time to sit there and babysit Orbi. For me my Sonos is running through the bridges so I rarely have a problem. The few times where I streamed UHD shows has been through the LG OLED TV running on the first floor where the satellite is and I have not had a problem. So as time permits I will try steaming thru the XBox One S on the first floor and see what happens. I would expect with UHD that I would need a constant connection or 15mbs or I would start having problems. A question I have does Orbi store logs from past days or only from the current session/day?
- DarrenMDec 20, 2016Sr. NETGEAR Moderator
Hello ruby49
I checked my logs it had stuff up to 5 days old so I am guessing it stores about a weeks worth of logs.
DarrenM
