Elgreco3
Aug 30, 2018Aspirant
Adding a second orbi satellite
I have an RBK50 dual pack.
(Router plus a satellite)
I want to add another satellite to cover an upper floor of my house but because my router is in the basement and the satellite
is in the...
Elgreco3
Aug 31, 2018Aspirant
Yes, thank you, I understand, maybe I didn't phrase it properly.
The question is whether I can do the second connection using an ethernet wire and not wireless
as my distance would be too far going from the basement to the second floor.
Is it as simple as connecting it through the ports on each unit ?
And if that is the case, I shouldn't need any special pairing or anything since it's wired right ?
Aug 31, 2018Guru - Experienced User
