Elgreco3
Nov 12, 2018Aspirant
Adding a second orbi satellite
Hi guys. I plan to add a second satellite and wanted to know if instead of just buying a satellite off Amazon as a single unit, could I get another dual pack (router +satellite) and just add the sate...
Nov 13, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Elgreco3 wrote:
Hi guys.
I plan to add a second satellite and wanted to know if instead of just buying a satellite off Amazon as a single unit, could I get another dual pack (router +satellite) and just add the satellite to my existing system?
Mostly because the price for the pack is even lower than just buying the satellite alone. Crazy..
Thanks.
Elgreco3
Nov 13, 2018Aspirant
3 floors total.
Router in basement, first satellite in middle floor and now I want to add anither satellite upstairs.
Btw, plan to use the second satellite wired to the router because of the distance,
So I just want to buy another but if I can use the satellite from another combo, then it's cheaper.
That's all.
That's all.
- FURRYe38Nov 13, 2018Guru - Experienced User
You should be fine. Just make sure the distance between is good. Starting is 30 feet in between. Wired or wireless.
Elgreco3 wrote:
3 floors total.
That's all.
