geocod's avatar
geocod
Adding a switch to RBR10
Added a 7 port gigabit switch downstream of the RBR10 and not getting any connection through it to lan to wired home security system need some help suggestions
Thanks
  • FURRYe38's avatar
    Try a NG branded GS108 or GS308 non managed switch.
    Be sure LAN cabling is good. CAT6 is recommended.
    • geocod's avatar
      geocod
      Tried several cables, all work with direct connect to RBR to security system
      Will give this a try.
      Thanks
  • michaelkenward's avatar
    michaelkenward
    Can you connect the security system to the RBR10 without the switch?
    Does anything else work when connected to the switch?
    There are three things involved there, router, switch and security system. Answers to these questions will help to pin down the problem.
    Just another user with time on their hands.
    • geocod's avatar
      geocod
      security system connects when direct connected to RBR10 lan port, all other connections through switch work , need the extra lan connections as RBR was only 1 port
      Thanks
