larodan
Aug 01, 2025Aspirant
Adding a used satellite
I have an RBR50 and a RBS50 network. I am buying a used RBS50 to add to the network. Should i do a factory reset to the used RBS50? Then should i do the add a satellite procedure in the Orbi ap...
- Aug 04, 2025
Thank you the installation following your instructions was completed with success.
CrimpOn
Aug 01, 2025Guru - Experienced User
Yes, do a Factory Reset.
Yes, use the Add Orbi Satellite process on the web interface.
After the satellite is on-line in Attached Devices (which can take LONGER than any human thinks necessary), use the Firmware Update menu to confirm that the router and satellite are on the same firmware release.
The current firmware for RBR50/RBS50 is v2.7.5.6
