larodan
Aug 01, 2025Aspirant
Adding a used satellite
I have an RBR50 and a RBS50 network. I am buying a used RBS50 to add to the network. Should i do a factory reset to the used RBS50? Then should i do the add a satellite procedure in the Orbi ap...
- Aug 04, 2025
Thank you the installation following your instructions was completed with success.
larodan
Aug 04, 2025Aspirant
Aug 04, 2025Guru - Experienced User
Enjoy. 📡
