JimCoho
Jun 18, 2020Aspirant
adding beyond 3 satellites for orbi ac2200 RBK44- possibly via daisy chain?
Hi, I have an old home with stucco walls and some deadspotes despite my 3 satellites and the router stuck in the basement. I am tired moving my orbi satellites around to accomodate reception. I read there is a limit of 3 satellites spoked on this system.(sorry I am not technical). Can you daisy chain additional ones onto these 3 to add another satellite or 2? also which satellites would be compatible with my orbi ac2200 RBK44? Thanks, Jim
It's possible. Other have posted having 6 RBS connected though didn't mention if Daisy Chain was in the configuration.
- JimCohoAspirant
Ok thanks. I'll see if any others respond about the daisy chain idea beyond the 3 satellites. are there certain satellites compatible with my older system(2018) that you know about? Thanks
RBS20, 30, 40, 50, RBS50Y outdoor, and RBW30s are all compatible.
