Neil_Fawcett
Jan 31, 2019Aspirant
Adding Orbi onto a Sky Q router - Couple of questions
I'd be looking to do the following:-
Disable the wireless network on my Sky Q Router.
Connect the Orbi to an ethernet port on the Sky Q Router.
Enable a wireless nework on the Orbi with the s...
Neil_Fawcett
Regarding your second suggestion of a DMZ - which I'm not familiar with - I'd surely have to ensure the Orbi gets a fixed IP address by defining that in the Sky Router, so the DMZ rule stays valid?
Or would that static address be defined on the Orbi?
Jan 31, 2019Guru - Experienced User
Setting up a reserved IP address ON the modem would be recommended in either case of router or AP mode. Look into using the DMZ on the modem for the Orbi if your wanting to try it in router mode.
- Neil_FawcettJan 31, 2019Aspirant
Well, I seem to be able to define a static IP address on the Sky Router for any device, and there is also the ability to set an IP address for a DMZ along these lines (although this is from a previous version of the router... but it's similar to my newer one) -
I assume then all ethernet (wired) devices would be plugged in to the sky router, and NOT the Orbi router then? And my existing port forwarding rules on the Sky router would continue to work etc...
Or by setting up the DMZ would all control be passed to the Orbi so it would need everything (wired) plugged in effect into it, and nothing else in the Sky router?
- FURRYe38Jan 31, 2019Guru - Experienced User
Only if you choose to use the Orbi in AP mode.
Yes, you are correct if you want to use the Orbi in Router mode.
So if I go down the DMZ mode to connect the Orbi to my Sky Q Router:-
- Nothing but the orbi would be wired to the Sky Q Router (& its wifi would be disabled)
- All wired connections would go into the Orbi
- Static IP address definitions I currently have on the Sky Q Router (for other devices) would need to be moved to the Orbi?
- Port forwarding rules I currently have on the Sky Q Router would need to be moved to the Orbi?
In effect that DMZ definition meaning the entire buck for everything except the internet (fibre) connection is being passed to the Orbi, with the Sky Q Router being left almost doing nothing?
