Takson
Jun 11, 2018Follower
Adding satelite fails
Hi all,
I have had an orbi + an orbi satelite up and running for a few months.
When I bought the system in December last year I also bought a second saltelite for when we completed some w...
Jun 11, 2018Guru - Experienced User
You would have to downgrade the Orbi router I think back to that version of FW. Then connect the one satellite, upgrade it manually with pre-downloaded v2.1.4.10 file. Then upgrade the Orbi router back to v2.1.4.10...
