fatsister
Oct 27, 2022Guide
Adding secondary router
I am needing WIFI in my shop which is 150' behind my house.
My house has an Orbi39 router with two satellites but the signal is weak in the shop due to the inability to space the satellites appropriately. I primarily use internet for streaming, cameras, etc.
My thought is to add a router and run ethernet (thru conduit) to the shop for the second router. I would want the new router to be the primary and the Orbi 39 to be in the shop.
Number 1: Is this feasible?
Number 2: Which router would be compatible for this application?
Simple explanations are appreciated.
Nancie AKA Fatsister
Number 1: Is this feasible? Yes.
Number 2: Which router would be compatible for this application? You could put in a RBS20, RBS40v or RBS50 ethernet connected to the RBR thats in the home. https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
Or ethernet connect a EX7700 or 8000 extender in AP mode.
My problem is, it's around 120' for access to electricity between the house and the shop. Too far for my satellites to get a solid signal.
Thanx
