orbi-fan's avatar
orbi-fan
Adding to my Orbi system
I have the RBK53 system with the RBR50 and 2 of the RBS50 satellites.  I would like to add a couple more satellites at odd locations (out in my shed, out on the deck) and am wanting to know which units I can look for that will still run on my system at full speed.  I saw something once that maybe said something like using other than RBS50 would slow down the back-haul or something?  After doing some research, I am pretty sure that these units would work as satellites with my RBS50 but will they run at full speed?
RBS50, RBS40, RBS50Y, RBS20, RBS30, RBW30
1 Reply
  • plemans's avatar
    The only devices that support the full 1733mbps backhaul are the 50 series. so the RBS50, RBS50Y
    The others will work but their backhaul will be the 866mbps. Not a huge issue provided you don't put one in the middle of a daisy chain.
    I've use the 50 and 30/40 series together and can't tell which I connect to because I'm usually not saturating the full backhaul speeds.
