Saldon
Jul 05, 2018Aspirant
Additional Ethernet ports for base station
I would like to add additional ethernet ports to the Orbi Base station. Right now I have some plugged into the Orbi base station and some plugged into the Verizon Fios modem. Is this a problem or c...
Jul 05, 2018Guru - Experienced User
You can connect a NON Managed Gb network switch (5 to 48 port) up to the back of the Orbi router if you need additional ports then connect all of your LAN devcies to this switch. I have a 24 port and other 8 ports connected to my router.
