Rupert22's avatar
Rupert22
Additional range extender for ORBI RBK50
I have the RBK50 system - Router + 1 Satellite - and want to extend the wi-fi range to my garage to operate a (wi-fi) outside security camera.
Is the ORBI "wallplug RBW30" the soution - i.e. is it compatible with ORBI RBK 50?
Or do I need an RBS50?
  • FURRYe38's avatar
    I believe it is. However I've seen other user post about having problems with the RBW30. Can try it and see. If it doesn't work well for you, go with the RBS.
    • Rupert22's avatar
      Rupert22
      Many thanks.
      However I've since seen numerous reports of ORBI wifi connection problems with my intended Ring Floodlight security camera - which seems to be incompatible. So, it's back to the drawing board.....and further research to find a compatible camera!
  • FURRYe38's avatar
    I have 3 D-Link cameras connected to my Orbi. Working fine.
    Good Luck.
