AndyKnight
Feb 22, 2018Aspirant
Adjusting signal strength per satellite
Is there a way to adjust the signla strength per satellite from telnet etc? I would like my rbr40 to be set at one signal strength and my 2 plugin satellites (rbw30's) to be set at a higher strength...
Feb 22, 2018Guru - Experienced User
Having this would probably mess with way the mesh system works. You can adjust the power levels on the router I believe.
