AndyKnight
Feb 22, 2018Aspirant
Adjusting signal strength per satellite
Is there a way to adjust the signla strength per satellite from telnet etc? I would like my rbr40 to be set at one signal strength and my 2 plugin satellites (rbw30's) to be set at a higher strength...
st_shaw
Feb 22, 2018Master
This feature is not available on Orbi, which is a bit disappointing, because adjusting individual AP power levels is standard practice for optimizing roaming performance. Other managed APs, such as Unifi, have this capability. I supposed it's due to NETGEAR's design goal of keeping things simple to configure, which sometimes involves compromises.
Feb 22, 2018Guru - Experienced User
I presume since this is a MESH system that some features like that are not compatible which could make the MESH system not work right. NG probably chooses to ensure the MESH system works well and lets the system handle everything. Any changes more than this could effect how it all works. Also roaming is mostly handled by the cllient devices and there algorythms as well.
- AndyKnightFeb 22, 2018AspirantThe reason I'm asking is because I've had to compromise on where I place the router and satellites so it would be handy to be able to tune the signal strengths of the fronthaul networks on each of the mesh components.
- FURRYe38Feb 22, 2018Guru - Experienced User
Placement and the signal levels would be handled by the system automatically and where the connections are done by the client devices as well.
- st_shawFeb 22, 2018Master
As AndyKnight indicated, there is often a need to adjust the client radio power of each Orbi AP individually, to achive good coverage without excessive overlap. Overlap causes difficulties with roaming.
