AndyKnight
Feb 22, 2018Aspirant
Adjusting signal strength per satellite
Is there a way to adjust the signla strength per satellite from telnet etc? I would like my rbr40 to be set at one signal strength and my 2 plugin satellites (rbw30's) to be set at a higher strength...
AndyKnight
The reason I'm asking is because I've had to compromise on where I place the router and satellites so it would be handy to be able to tune the signal strengths of the fronthaul networks on each of the mesh components.
Feb 22, 2018Guru - Experienced User
Placement and the signal levels would be handled by the system automatically and where the connections are done by the client devices as well.
- st_shawFeb 22, 2018Master
As AndyKnight indicated, there is often a need to adjust the client radio power of each Orbi AP individually, to achive good coverage without excessive overlap. Overlap causes difficulties with roaming.
- FURRYe38Feb 22, 2018Guru - Experienced User
Is this maybe something thats already being handled by the system itself?
There is no indication that it is being handled. Everything indicates it is not being handled. Properly adjusting the client radio AP power automatically would require input from the coverage area, and there is no physical way for the system to get that. There is also no precedent for this (that I am aware of) among any other competing systems.
I think the system could theroetically adjust the power on the backhaul though.
