StrikerXtreem's avatar
Mar 04, 2018
Advanced settings gone on my Orbi
My initial problem was that I have a Chord Polly that only can connect on 2.4 Ghz and the setup has to connect on the same bandwith with my iPhone. So I look and found out that it was possible in the Orbi admin centre to goto advenced and wifi settings and disable the SSID broadcast.
However when I logon the advanced tab is no different than the basic and nowhere can I find these options. Hope that someone can help me out here.
I have attached image of my admin page.
1 Reply
  • You should go to Advanced Setup-> wireless setup instead.
