Kerry2U's avatar
Kerry2U
Follower
Oct 12, 2020
Advanced Setup App for Orbi RBK50
Hello all, Is there an app that can be downloaded to access advanced setting in the orbi rbk50?
The settings available are not going to cut it.  I need to be able to forward ports, open and close others, and manage QOS.
Please don't tell me this device has the ability to do these things.
So far all I see is hype about PAYING to control safety features.
1 Reply
  • FURRYe38's avatar
    The RBRs web page does this. You can setup the RBR for your needs and onces it all setup, do a back up configuration to file for safe keeping. You can use this backup file to re-load the RBR or even a different RBR.
