WAP
Jan 14, 2018Apprentice
Advanced Wireless Settings: Enable 20/40 MHz Coexistence
At my office I have a Netgear business class access point. The 2.4 GHz radio has the following three choices via a drop-down for Channel Width: 20 MHz 40 MHz Dynamic 20/40 MHz (I've selected 20 ...
May 21, 2018Guru - Experienced User
Do you not have an Orbi system?
Use a wifi scanner...there free. https://www.acrylicwifi.com/en/wlan-wifi-wireless-network-software-tools/wlan-scanner-acrylic-wifi-free
Yes, if it happens that the device has to switch from 40Mhz to 20Mhz, the speed will be slower.
Geezer67 wrote:
Thanks but I don't know how to tell what channel(s) our neighbors wifi use.
Also, when you say that it does not impact range and coverage but does impact performance, do you mean it will be somewhat slower?
My router is a N750 WNDR 4300 if that helps.
Thanks again for your assistance.
Geezer67
May 21, 2018Aspirant
No, I don't have Orbi -- I just searched for Wireless Settings: Enable 20/40 MHz Coexistence and landed in this group. Hope that is OK?
Thanks again for your help.
- FURRYe38May 21, 2018Guru - Experienced User
Please continue to post here for your model router.https://community.netgear.com/t5/Wireless-N-Routers/bd-p/home-wifi-routers-wireless-n
Thank you...
