ekhalil's avatar
ekhalil
Master
Nov 14, 2018
Advice to Netgear!
I used many products in their early introduction and experienced different behaviors from the vendors when it comes to handling customer's feedback, trouble reports and complaints. I'll give you tw...
  • ekhalil's avatar
    ekhalil
    Nov 26, 2018
    Thanks for the reply Blanca_O
    This forum should be a gold mine for Netgear. I hope that Netgear developers make use of it as it should give them excellent feedback on their work.
