frankds
Aug 14, 2018Follower
Airplay is still not working - any fix expected?
I got two Orbi setups; Finally the WiFi is going trough the walls but Airplay is NOT working at all; mostly the devices are not even discovered (not even from Windows Airport admin tool) or if they a...
DarrenM
Aug 15, 2018Sr. NETGEAR Moderator
I will look into this and will let you know what I find out.
DarrenM
