Retired_Member
Jan 19, 2018Airplay music stream freezing with RBK40
Hi, I received my Orbi system RBK40 today. The installation went well and the speedness is as expected, however I have issues with streaming music using Airplay. Every minute or so the music ...
Retired_Member
Jan 23, 2018Thanks for your reply.
In the meanwhile I made following observations:
- When I stream simultaneously on my Apple TV, which is wired directly to Orbi, there is no freezing
- Screen sharing between two macs is also freezing, I never had this issue with a router before
I now lowered the 2.4ghz band to 75%. It didn't solve the issue.
Baptiste
Retired_Member
Jan 24, 2018Hi,
I tried with lowering the 2,4ghz band to 50% and 25%. It didn't help.
I then reverted to factory default settings. Same issue after reconfiguration.
Last day before I sent it back and let know potential buyers to be careful.
Baptiste
- Retired_MemberJan 24, 2018
Me again,
I downgraded to the Router Firmware Version V1.11.0.20 as per instructed here. This is an operation for advanced users only. It fixed immediatly the freezing issue, however I guess that the new firmwares were bringing other updates from which I obviously don't benefit now.
Any comments from a support perspective?
Baptiste
- PyroDogJan 24, 2018Apprentice
This is also my experience with the newer firmwares. It seems they get worse over time.
Firmware version 2.0.0.74 is what I recommend.
- Retired_MemberJan 27, 2018
Thanks!
I installed 2.0.0.56, which is the equivalent for the RBK40 and confirm that this version is also stable.
