cox8
Dec 20, 2017Tutor
airport express connection with orbi
Setup orbi network twice. From factory reset. Airplay will join the network using airport utility software. when I try to airplay sound from any device on the network it will not connect. I have mo...
cox8
Dec 20, 2017Tutor
I discovered if you disable Daisy-Chain Topology leave fast roaming on, MU-MIMO, Implicit BEAMFORMING enabled airplay does work with with airport express and airplay. It also worked with fast romaing off too. My speed stayed up past 230 Mbps too. Support was no help at all. I was told I had to put the xpress in client mode using a LAN cable. That is not an option. I will reply back if I have any issues.
