theronin_hunter
Jul 31, 2017Tutor
Alexa - Multiple routers found
Hi, If i activate the Skill and ask Alexa to activate my Guestnetwork, there is the following comment: "There are to many Routers found." - I only have Orbi in my house. Any Ideas?
DarrenM
Aug 02, 2017Sr. NETGEAR Moderator
Hello Theronin Hunter
Can you check the settings in Alexa see if it has multiple wifi connections saved?
DarrenM
- theronin_hunterAug 02, 2017Tutor
Hi,
No single wifi network stored
- theronin_hunterAug 07, 2017Tutor
Any other ideas?
- theronin_hunterAug 27, 2017Tutor
hello? still waiting
