theronin_hunter
Jul 31, 2017Tutor
Alexa - Multiple routers found
Hi, If i activate the Skill and ask Alexa to activate my Guestnetwork, there is the following comment: "There are to many Routers found." - I only have Orbi in my house. Any Ideas?
theronin_hunter
Aug 02, 2017Tutor
Hi,
No single wifi network stored
theronin_hunter
Aug 07, 2017Tutor
Any other ideas?
- theronin_hunterAug 27, 2017Tutor
hello? still waiting
- DarrenMSep 07, 2017Sr. NETGEAR Moderator
You may want to check and see if orbi is the only device under your remote access on your account.
DarrenM
- YnerJan 06, 2018Guide
I have the same problem. I went to the link you said, but there is no down arrow to select offline routers. When looking at the Alexa app I don't see a spot where I can see the wifi setting. I looked under settings.
Please provide more steps to get rid of this error. I would like the ability for Alexa to turn on/off the guest wifi.
