Tradebear
Oct 24, 2017Follower
Alexa Echo Dot won't connect to Orbi WiFi
I just got my new Orbi mesh system and I can't seem to connect my Echo products. Yes, there were connected to an old WiFi system, and Apple Base Station. I just can't get them to pair with Orbi's wi...
fliparagon
Nov 13, 2017Initiate
After no problems with my Echo connected to my Orbi, it randomly disconnected from the WiFi and would not reconnect. Tried resetting the Echo, resetting the router, tried connecting to the guest network, changing passwords, rebooting/resetting the Echo, router (including powering down), but still no luck. As a last resort, I decided to try and add the Echo's MAC address to 'Allowed' devices under the 'Access Control' section of the Orbi router control and noticed that under the existing list of devices, the Echo's MAC address was already listed under 'Blocked'. I have no idea why or how the device became blocked as I'm the only one in our household who knows how to access to the router controls (or would even know how to block a device). But for some reason, our Echo's MAC address was there.
After removing the Echo's MAC address from blocked devices and going through the setup process again, this time it reconnected and all is good. Not sure if you're issue is the same as mine but it's worth checkiing out.
- mike02Dec 31, 2017Aspirant
I had experienced the same problems trying to reinstall my Echo after moving it between rooms. Two days later I found this post... hoping that the Echo's mac address was "blocked". It was not... but... after deleting the Echo's mac address within the orbi login software... the Echo was able to reinstall (using the Alexa App) and hook into the wifi network.
