bengkohn
Nov 29, 2018Aspirant
All good, except for the magenta light
I finally got my router (as a wireless AP) and satellite the way I want, with an ethernet backhaul. The trick seems to have been to take the cable out of the internet port on the router and put it in...
ekhalil
Nov 29, 2018Master
Yes, the router ring will light magenta if nothing is connected to the WAN (internet) port.
How do you get internet access if nothing is connected to the WAN port (the yellow port)?
- bengkohnNov 29, 2018Aspirant
It is in Wireless AP mode, which should (and apparently does) mean that it just needs to be connected to the LAN somehow, so the LAN ports seem to work fine.
- ekhalilNov 29, 2018Master
No, AP mode does also require that you connect the internet source (a port from your router) to the WAN (internet) port in Orbi, otherwise the router will continue to have the magenta ring on.
The LAN ports can be used for wired devices as well as for wired backhaul.
Fair enough, thank you.
I will keep that in mind if I start to run into weirdness going forward, but for now it is working great.
