bjoergensen
Apr 17, 2019Follower
All WLAN keeps resetting every few minutes
I have an RBR50 with two satellites, which I've used for a year. They work ok-ish, with the occasional reset needed. Today the WIFI started dropping every few minutes, dropping all devices. Both ban...
Apr 17, 2019Guru - Experienced User
Any other wifi devices used in your home? Like roku or Sonos?
Does the wireless go down if you have both RBSs turned off?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try a Manual FW re-load and setup from scratch:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
