wvk's avatar
wvk
allow connection to L2TP VPN server in network (enable ESP protocol)
I have a server in my network (Apple Mac Mini), which has a L2TP VPN server running. My old router had forwarded these UDP ports to that VPN server: 500, 1701 and 4500. And: the IP-ESP protocol, wh...
  • peteytesting's avatar
    Dec 04, 2016
    hi
    when you sat the orbi sits behine another router is the orbi still running in router mode as well as if so you have dual wan
    to avoid the dual wan ether put the orbi in AP mode or bridge the up stream router
    of just connect thenvpn server to the up stream router and not the orbi
    you can port forward through 2 routers but its a pain in the ass
    here is a guide to forward through 2 routers
    https://portforward.com/help/doublerouterportforwarding.htm
