MarkLOrbi
Sep 28, 2018Guide
Alternative to IP passthrough
I have an AT&T uverse modem/router and the Orbi. Uverse continually has problems that I need to call AT&T about and the first thing I have to do is disconnect the Orbi or they blame all the problems ...
- Sep 29, 2018
MarkLOrbi wrote:
The only thing the orbi will be providing is wifi radios.
What you suggest is to use the Orbi router as a wifi access point.
There is a manual for the Orbi WiFi System somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
See the section Use the Router as a WiFi AccessPoint.
MarkLOrbi wrote:
Is there any downside to doing this?
Only if any of this stuff is important to you:Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Sep 29, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
