MarkLOrbi
Sep 28, 2018Guide
Alternative to IP passthrough
I have an AT&T uverse modem/router and the Orbi. Uverse continually has problems that I need to call AT&T about and the first thing I have to do is disconnect the Orbi or they blame all the problems ...
- Sep 29, 2018
MarkLOrbi wrote:
The only thing the orbi will be providing is wifi radios.
What you suggest is to use the Orbi router as a wifi access point.
There is a manual for the Orbi WiFi System somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
See the section Use the Router as a WiFi AccessPoint.
MarkLOrbi wrote:
Is there any downside to doing this?
Only if any of this stuff is important to you:Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
MarkLOrbi
Sep 29, 2018Guide
Great, that's exactly what I wanted. The only thing I would have liked to hang onto was a visitor network, but it's not that important.
